Wind direction popup on mouseover
This is probably something I should have seen ages ago. Anyway…
When I mouseover my wind direction gauge the popup shows the data plus the text Metar followed by a string of numbers and letters which change on each update. How is this being generated as it is not there in the customclientraw file? You can see what happens here.
I think thats cause you have metar enabled in the steel gauges settings??
I have looked but so far not found an appropriate setting. Do you know where it is?
Erm… looking now, mine is built in to a template so bear with lol
Sorry Stuart, i aint got a clue, its not all straight forward, i.e. no settings file that i can see, someone
with more power than i have should be along soon
Just a thought, is it pulling it from your settings.php?
My pages dont use a settings.php file at all, so no.
I don’t (currently) provide a switch for the METAR string. It shows if you enable display of the wind variation.
If you want to remove it, then the ‘standard’ gauges.js script I supply would have to be modified, just remove “ssGauge.VRB” from the code creating the pop-up…
In singleDir() change…
                    if (ddimgtooltip.showTips) {
                        // update tooltip
                        tip = strings.latest_title + ' ' + strings.bearing_info + ': ' + cache.valueLatest + '
Thanks Mark.
The thing which made me question it is that it seems to be a string of meaningless characters. Can you explain what this string represents and why you decided to use it please?
Its the Metar data, below is an example of one,
METAR: KDDC 071452Z AUTO 21004KT 7SM BKN004 BKN041 OVC055 12/12 A3014 RMK AO2 SLP201 T01220117 53014
What all that means is this (you can match it up to see)
Temperature: 12.2
That’s interesting Bashy but the text string appended to the word METAR on my popups looked nothing like that, and if it is an example of what a METAR string should be from my site then way have it on the Wind Direction popup only.
It just shows the sub-set of a full METAR string relating to the wind strength/direction only. From memory the format is dddssGgg fffVttt
where…
ddd = current wind direction in degrees
ss = current wind speed
G - gust information follows
gg = latest gust speed
second string is variation in direction in last 10 minutes…
fff = from direction in degrees
V - varying to…
ttt = to direction in degrees
Thanks for the explanation Mark. To be honest I’m glad I turned it off since it would be likely to not be understood by many using the site.
So do I, so I have updated the script so that string is now disabled by default, and there is a config item for switching it back on.
