We seem to get a lot of posts asking exactly the same question, when a Forum Search might quickly produce the answer you need. I recommend using Advanced Search.
Happy searching
LATER EDIT: Search is different to the old Forum, but if you click on the hamburger in the search box (advanced search) you can narrow it down a bit. . .
Brian beat me to it, I used to be frustrated in not finding something I knew I had participated in or some of the key words, but was not using the magnifying glass to initiate the search, which finds LOTS of the things I was thinking of.
I still ask dumb questions, but fewer since I found that there is a difference between the box and the glass
Not sure. . . There is already a lot of documentation at PWS_Dashboard start that should not need to be duplicated here, so it would not be fair to expect Wim to produce FAQs as well. I run a very old version of the dashboard and do not necessarily understand all the features of the latest version, so if I answer a forum question I often have to check the documentation and/or search to find the answer first.
Maybe I should have headed this thread “Please check the documentation and try Forum search before you post”
