With some difficulty, I managed to follow the instructions in the FAQ for the basic web page. The server directory includes
.gif
There is no .htm, which I expected.
I did find this file in D:\weatherdisp\webfiles, along with numerous other files, many of them HTML text files.
Obviously, I can copy this to the server directory with an FTP client, but it would probably not be updated.
What have I done wrong?
Second question: Much of the web info is in the form of .gif files. How can I edit what is displayed on these? There is much irrelevant data, which has nothing to do with my primitive cheapo station.
I’ve tried several things, no success, so far. However, I felt the whole proggy was hogging all my computer resources, so I thought there was more amiss than just this problem. I uninstalled the prog and tried re-installing, but saw it retained my set-up. I therefore uninstalled again, deleted every ref I could find to WD, including in the registry (31 keys), so I thought I had a clean machine. I reinstalled to a new directory, but it still had all the details of my first installation. I then tried to set up the web from scratch to a different server directory: identical result, no .htm.
What is the file name where the data is stored; certainly not in the weatherdisp directory???
Thanks a lot. It was the ini file in the windows directory that was causing me grief. I’m starting a new install now and will let you know how I get on.
Suggestion: should the location of the ini file be published in the FAQs?
I now want to get the page looking like I’d like it to look, mainly the table. I’ve a feeling that I’ve many more questions before I’m through, though. :?
One question re the default page, though. At the bottom, it shows:
Sunset at:
16:33:54
Moonrise at:
16:36:33 16/11/05
Moonset at:
06:32:02 16/11/05
First Quarter 9 November 2005
Full moon 16 November 2005
Last Quarter23 November 2005
New moon 1 December 2005
Moon age: 15 days,2 hours,46 minutes,100%
Hours of possible daylight today was 12:07:00
Locate the datahtm3.txt file in your webfiles folder and paste the code here from that file as it normally will contain at least the following:
<CENTER><P>
<HR WIDTH="100%"></P></CENTER>
<CENTER><P>
The data is logged at two minute intervals, but there is data recorded every minute.
Best viewed in 800 x 600 and True colour.
<center><p>Use the <font color="#FF0000">RELOAD</font> facility
on your browser to retrieve the latest data.</center>
<CENTER><FONT SIZE=+2><A HREF="weekrep.htm">Click here for a daily update of the averages/extremes to date for the month</A></FONT></CENTER>
<CENTER><FONT SIZE=+1><A HREF="http://www.weather-display.com">Created by "Weather Display" software version 10.30a at this start time/date 10:47:51 AM 11/12/2005</A></FONT></CENTER>
</BODY></HTML>
Which i don’t see as being included in your .htm file…
Sorry, misunderstanding! When I said, “At this stage” I meant at the time I posted the message. Yes, I subsequently did make some modifications to some of the *htm?.txt files to eliminate some of the superfluous info. I was unable to eliminate the summary and some of the other stuff. I really want only the table, but modified. I think I’ll work on an ad hoc web page containing only the info I wish to publish. I’ve printed out the customised web page data as a first step.
I’m asking a further question or two in a new thread.
