14 Visitors online right now
Max visitors today: 14 at 11:35 pm PST
This month: 26 at 12-12-2008 06:01 pm PST
This year: 26 at 12-12-2008 06:01 pm PST
All time: 26 at 12-12-2008 06:01 pm PST
I think I will make the whos-online page admin view only on my web site.
I will still add the feature to disable the ip addresses display for those who want to use it publicly on their web site.
… too tired tonight, will look at it more tomorrow.
Yes you can use it without the templates, see the readme.txt
Optional template install)
It helps if the site already has a settings.php or similar include file so the include-whos-online-header.php file can easily be included for every page.
PHP4 works, I have php5 though. let me know if there is any trouble.
I have it on my home page (took a while to sort it out)
I see the Database name is showing, is there away to stop that please? http://www.northantsweather.com near the bottom right
I also have the script running in a seperate page but i dont think its working
right for me, i think i done something wrong as clicking on IP addresses and
changing settings dont work, any ideas what i broke please?
Because many web hosts use different types of control panels, there are different ways.
Usually your web host will have a FAQ or help guide to show you how to add a database.
After you add your database, create the tables with whos-online.sql.txt
If you use phpMyAdmin; you can select your new database,
then paste the contents of whos-online.sql.txt into the SQL statement entry form.
You must have changed some things because I cannot duplicate the problems you are having.
I have no idea why the table name is printing in the page, the script should not do that unless you changed something.
ip links not working …
What did you set for $C[‘whois_url’] ?
for the whos-online.php not working …
the $C[‘filename_whos_online’] setting was only designed to use one type of page such as php, so it would have to be set to
whos-online.php for that page to work
… also your records are showing millions online, I do not know why.
