Where are yearly and monthly rain stored?
I need to correct errors in yearly and monthly rain for 2025 and I have tried to find statistics file where this is stored, but I’m not able to locate it.
Kindly guide me which file to look for.
If you click on the main screen rain area the blue Rain To Date screen appears, and at top right you can select Detailed Rain data and edit it there.
There are no links in that tile as I can find.
Ah, sorry, I thought you meant in WD. . .
If you use WU for graphs in pws-dashboard, you can edit the rain values by running _wu_upd.php to edit the arrays.
What’s the URL to your site?
That data comes from the history file. Normally lthe sky block has a link to it.
Historiske målinger av værdata
You can edit that file with
https://weather.meisal.com/PWS_hist_update.php?pw=YOUR_EASYWEATHER_PW
If you use an incorrect password the message reads “Sorry - not possible”
The update screen should look like this:
Succes, Wim
Thank you Wim!
Sorry for not including website url, but you managed to find it anyway:-)
Kjell Inge
