Would the data found in the ‘Weather Data’ table on THIS page originate from a raw .txt file such as THIS? I am in talks with that site’s admin on a solution for me to link to his weather stats and produce my own weather display in php.
That table is part of the default webpage produced by Weather Display.
you can change the datahtm0.txt and datahm3.txt that forms part of the default web table
of you could create your own using custom tags…from a template…there is an example template included with the wd install files
niko, what data (.txt?) do you use to create the image in your signature?
It’s from clientraw.txt - check out this thread
Thanks, so from my understanding all I need to do is edit the two .php files in the wxgraphic archive to suit my needs incl. linking to the relevant clientraw.txt and uploading the lot to my server. Then possibly using a php include command I could insert the image into my wesbite here?
As written it is designed to look for the clientraw.txt on the same server so your source would need to upload a 2nd copy to your server. I imagine it can be modified to read it from another server but that’s outside my experience.
And can this second copy be uploaded to my server by simply inputing my details into the “Second FTP Server” area of the WD control panel? And this will not affect the primary copy being uploaded to the club’s (sources) server?
This thread locked to avoid confusion, let’s post everything in the other thread.
