ftp ot not doesn’t matter, ftp.barryweatherstation2.co.uk or barryweatherstation2.co.uk will work equally well as the name of your (e-rice) FTP server.
I have your settings files
you have not set up anything in the Ftp/internet setup, connections setup, for the FTP settings, and the main internet switch is not on there either
note : did you go action, export registry settings, in WD, before emailing me the updated zipped wdisplayftp.reg file?
Brian
Yeh clicked on Action then Backup Registry files as Saving Settings/Configuration Files for Troubleshooting then opened files and zipped them.So should be up to date.
Will check out the settings as you mention.Should the switch Advanced Internet Settings also be on ?Thanks Rob
if you use the customise internet and file creation setup (advanced internet settings) then you need to make sure you set the times to create and times to upload for the files needed and you set the needed remote filenames
Looking at the website locally on WD on the pc it appears to updating ok now.When i Google the webpage for example i am viewing outdated data.Having re-entered the FTP Server etc; as instructed and set upload times does’nt appear to show live/updating on www.
Rob
It looks like some elements are updating…
http://www.barryweatherstation2.co.uk/summary.gif
As Brian mentioned if you are using the Internet File Creation and Upload you must have both create and upload times set for all the files you want to upload… So the first thing we need to know are you using Internet File Creation and Upload?
Yes i am and believe that i created and uploaded each file as per instruction…but you never know !!.Rob
