I want to store in wdisplay folder and they end up in wdisplay/webfiles - Even though I initailly set it up for this directory when I reboot it defauls to the webfiles directory
Setting file save at ‘File Save’ tab in WebCamCapture Set-up
I have mine set to save to C:\Wdisplay\webcam and the settings stick.
Try setting to the directory you want (I wouldn’t recommend the main directory myself) and then let WD run for a bit making sure the files are going to the correct location and then manually close WD from Exit and then relaunch and see what happens…
