Webcam autorefresh
I would want to know if the program weatherdiplay webcamimage 6.2 has the option autorefresh the image of the webcam and if it is you could yourselves be indicated the setup to me?
Fabry
Fabry,
I am not sure I fully understand as when viewing the webcam image from WD webcamcpature it is live all the time…
Do you mean having the image autorefresh within your webpage? If so what webpage? A default WD page or a custom one of yours?
Hi Bob
Yes autorefresh within inside my webpage Redirect now i using other software but soon I will comeback weather display webcam , now I got vers 5.7 where I update to vers 7.0
sorry for my English
Fabry
latest version:
http://www.weather-display.com/downloadfiles/wdwebcamcapture.zip
7.1
then you can set wd to ftp the web cam image to your web site, see in the webcam ftp upload in the ftp/internet setup
(select the file and tick to upload the files in the list)
ok you send me print screen to help me setup just
Fabry
Fabry,
You already have an autorefresh for your webcam in your WDL, it is in your WDL Config file:
http://www.clicklivorno.com/wdlconfig.xml
http://www.clicklivorno.com/cam_1.jpg Meteo webcam Livorno Italy 120
That is a two minute refresh and you may want to adjust to every 30 seconds or so depending on how often you upload…
ok
It not possible update about 5 second?
why not update inside image temp and wind direction and wind intensity but update only time ?
fabry
Fabry,
If you are uploading your webcam image every 5 seconds you could set the refresh for 5 seconds however most folks don’t upload their webcam images more then every 30 seconds or 1 minute or as in my case 5 minutes…
ok I make all ok http://www.clicklivorno.com/webcamimage1.jpg ,another last thing wich code for webcam streaming?
Fabry
Fabry,
Webcam streaming can’t be done with WDL. You would have to enable network streaming on your webcamcapture setup screens and then provide the URL, your ISP assigned IP address, as shown in WD for folks to access streaming.
You can embed it into a webpage but not WDL and you can locate different methods for embedding searching these forums or searching the web for embedding Microsoft Streaming…
