its dependent on your windows regonal settings for time format…
what i need to do is make them both the same (i.,e the first one that same as the second one)
i have been meaning to do that, but have not got a round tuit yet
i have a square tuit, but not a round tuit…they are hard to come by
which time format would you want to see (of the 2)
try tweaking your windows regional settings, time date settings…and set the time format you want/need there
Hi Brian - not fussed, as long as they are the same. My Windows setting is currently 12 hour time with AM/PM, so I take it you mean if I change it to 24 hour time, it will then show 24 hour for both? I’ll give it go now. I assume if I wanted to have 12 hour, then I would have to delve into the WD settings somewhere - which I might avoid, as I tend to mess things up if I play too much in amongst them :?.
