Web cam on PWS Dashboard
Ja, ok but now iSpy start to reboot like crazy . Modens , My computer must be switched on all the time and iSpy should run , right? Becouse, I see that when the PC is off , the picture is not updating.
I use iSpy and it uses a lot of CPU time unless you cut the frame rate right down: I use 1 fps. And yes, the computer has to be running.
It is not possible to do some settings now in to the software. It is keep rebooting . Should I reinsall the program?
I tried to reinstall iSpy , but it is the same rebooting . No chance to do same settings . Is there anouther soft that can be used , analog maybe?
Just to answer:
I don’t know of any other programs that can be used.
Did you uninstall the old iSpy or install the new one on top of the old one? It may be important to uninstall and remove any possible corrupted files.
Yes , I uninstalled the old one first . End then I tried to install it again .
I managed to install the older version of iSpy and it works now . Where to find frame rate to cut it down to 1 fps?
Click on the on-screen settings, first tab “Camera”
That is what I have , but no frames
. . . I think. Mine says 1, anyway.
Now it is showing empty screen on camera place and stoped to steaming .
I can’t find any other setting. . . here’s mine:
Maybe the camera can’t handle it. . . try increasing the frame rate a second at a time.
Now it is working , updating the snapshots on the server , but…I can*t figure out witch map to point out . Some how I manage the first time , but now it is difficult.On the screenshots, with the blue arrow ,I point the file that uppdates on the server . With the red arrow , the file witch is showing on PWS Dashboard.How to point the file that will appear in to the PWS Dashboard!?
Finally , success! :innocent:
Very useful post . Thank you ,Wim!
