Well, I haven’t made a post here since November 2003 as WD has been working just great! Good job Brian !!!
I’ve run into a problem thats been going on for the last few versions. WD is shutting down on me daily between 0605 and 0610 EDT with the followinig error:
WEATHERD CAUSED AN EXCEPTION 10H in MODULE at 0000:00000000
STACK DUMP
(Sorry for the shouting apperance, but thats the way it’s written).
Anyway, currently i’m using version 10.13w
Ideas?
there is some calculations done at that time…
which weather station type?
also
try backing up and the deleting the datafile month72003.inf
http://www.appalachian-weather.com/
i see you have a davis VP…
do you have wd set to update the vp time daily?
that might be the problem
under setup, control panel, data logger setup…and the tick, do daily, next to where you update the time…
that routine is done at the time it is crashing
I do have it ticked; changing it now. Will let you know what happens!
Brian…that was the problem. I’ve removed the tick and no longer have crashes.
Thanks !
