Weathercloud CRON Job
Hi, I don’t know where to enable the separate cron job for pushing data to Weathercloud. Any information is appreciated.
-Joe
Ver: 10.37Mac310
there should be a croncloud program in the resources folder that WD runs
what shows in a terminal window when you run that program ?
Brian, below is the output from the croncloud. When I click the TEST button in the WeatherCloud set-up in Control Panel it does push the data the WeatherCloud but does not send otherwise.
/Applications/weatherdisplay.app/Contents/Resources/croncloud ; exit;
weather clouddata to send
weather cloud data send failed 17:17:11
logout
Saving session…
…copying shared history…
…saving history…truncating history files…
…completed.
Deleting expired sessions…9 completed.
Joe
that is important information to know
is the switch on in the weather cloud setup ?
is there any errors under view, program event log?
The switch is set to blue.
Program event log contains one line: Resetting warmest day values 06:01:37 03/02/2019
email me your settings files and I will check/test here
Sent setting info.
Q:
do you have WD Mac version set to get live weather data from your weather station?
i have fixed this now
latest update or use this update to the croncloud program
http://www.weather-display.com/downloadfiles/croncloudmac.zip
I am seeing a similar issue WeatherCloud cron jobs on 10.37Mac358. A test from the control panel is successful and my station is updated on WeatherCloud.
This is the successful url:
http://api.weathercloud.net/set/wid/[MYWID]/key/[MYKEY]/temp/93/tempin/191/chill/87/heat/93/hum/43/humin/42/wspd/10/wspdhi/15/wspdavg/13/wdir/137/wdiravg/130/bar/10166/rain/0/solarrad/0/uvi/0/ver/1.2/type/201
I have run croncloud from within weatherdisplay.app and it returns an error:
http://api.weathercloud.net/set/wid/[MYWID]/key/[MYKEY]/temp/132/tempin/192/chill/108/heat/132/hum/34/humin/41/wspd/62/wspdhi/77/wspdavg/69/wdir/170/wdiravg/164/bar/10149/rain/0/solarrad/1180/uvi/0/rainrate/0/thw/1490/et/0/ver/1.6/type/201 Error -1022 accessing to http://api.weathercloud.net/set/wid/[MYWID]/key/[MYKEY]/temp/132/tempin/192/chill/108/heat/132/hum/34/humin/41/wspd/62/wspdhi/77/wspdavg/69/wdir/170/wdiravg/164/bar/10149/rain/0/solarrad/1180/uvi/0/rainrate/0/thw/1490/et/0/ver/1.6/type/201: The resource could not be loaded because the App Transport Security policy requires the use of a secure connection.
The Mac is running High Sierra 10.13.6
