Please add the following: :lol:
High UV
High Solar Radiation
Cheers
Cyclone
High UV
Cheers
Cyclone
Also, for the Custom Web Page, could you add words for the Fire Weather Index (low, high, etc )
Cyclone
Hello,
Could you please add rain rate warning.
Cyclone
too hard basket ?
Cyclone
%FWIffmc%…Fire weather index fine fuel moisture code
%FWIbui%… " " " build up index
%FWIisi%… " " " initial spread index
%FWIdmc%… " " " duff moisture code
%FWIdc%… " " " drought code
%FWIfwi%… " " " fire weather index
those tags exist, but not sure what you mean by hi/lo fire the fire weather index,…do you mean the description of the current status?
also, in wd, hi uv and hi/lo solar you can see under view, Davis VP extra information (the lightbulb icon)
i will add rain rate alarm
The UV and solar i was refering to in weather warning.
The fire codes i’m refering to is low, moderate, high, very high & extreme.
Cyclone
Am i asking for too much? #-o
Cyclone
i will get there, but there are alot of requests at the moment in WD, and each person thinks they are the only person and that they should get top priority…and when i work on someone elses request, then someone gets upset and impativent, and its like, why are you not working on my request?
then i get people who just get mad at me…
and its a very busy time of year for me,…but things will be a bit better…
I do get there in the end…
sure would like a break though, been 4 years of nearly non stop…and it just keeps on coming
Yes windy,
take a break but come back soon.
i will take a break once i get caught up…i might have to lock the feature request though, 3 new requests there today 8O
[quote author=windy link=topic=6129.msg44255#msg44255 date=1103137922]
just working on the solar/uv warning now…
hey, your signature is looking good…how are you producing that?
If that was to me about the sig, I am using image salsa…
ah, thought you might be
with wd and a custom screen, you could do the same thing pretty much
That is a part of WD I have not worked with yet. It has been easy to use image salsa because my camera is on another computer in another part of the house and I needed a capture program on it anyway.
Chad
i have done the solar and uv weather warning now
in a new 10.20m zip
which will be ready to download in about 1 hour or so (check the time stamp on the download page)
now off to look at the Degress day warning
Thanks mate
Cyclone
I’ve opened this up again, because i think its fire season in the northern hemisphere, and fire season here in a couple months,
A custom tag for the fire weather index: for example
if FWI value is
0-a = low
a-b =moderate
b-c = high
c-d = very high
d+ = extreme
Good luck
Cyclone
