Noticed today that my weather underground pages isn’t being updated “live” after going through everything I also noticed that this past tuesday my temp data is screwed up every now and again the same 81.2 degrees pops up on the Weather Underground graph but the data on the station(hardware) is correct and even the data in the weather display graph is correct but ever few hours 81.2 will pop up on the weather underground data… like today its been mostly 71 5to 73 degrees a lll day but about 7 times today the its popped up to the 81.2 on the weather underground site only… and LIVE data is still NOT being sent… All this happened in the last few days with 0 computer changes…
Could you post the URL of your Wunderground data page and also a screen shot of your Wunderground settings page in Weather Display?
Also have a look in the FTP logs within WD and see if there are any errors showing. You’ll find the log files in the wdisplay program folder called “ftplog.txt” (the log for today) and “ftplogfull.txt” (the log of the last FTP upload).
If you do a test send to Wunderground from the WD setup page, then open the ftplogfull.txt you should see something like this in there:
Connection status OK Wunderground connected status: OK Status OK Completed Connection status OK Disconnected OK
One other thing; are you using Rapid Fire for the uploads?
is the separate WD wunderground rapid fire program running?
its also possible that its a problem on wundergronds end, sometimes it can happen where another station is sending to your account
or make sure there is not another copy of WD running on your pc that is sending the bad data
