Weather Underground and Weather Displays' Weathermap
Hello,
Seems WU isn’t quite happy with their data formatting as a recent change (within the last several days)
has borked WD’s Weathermap feature.
Using the default URL for a station IE: wunderground.com/weatherstation/WXDailyHistory.asp?ID=KMDELLIC3
refuses to update the weathermap. Dropping back to the classic URL, Local Weather Forecast, News and Conditions | Weather Underground,
isn’t any better.
Is anyone aware of these changes?
My WD mesomap isn’t working either. It seems as if WD will only collect the 00:00 time.
I’m also having the same problem.
what /where/how?
need more details…
See screen shot link below @ 19Z today from the WD WeatherMap Setup after I clicked on Update Now. The observations are from 10/29/11 00:00:00 with a couple at 06. Looking at Weather Underground for the stations the data is up to date.
http://www.harpersferry-weather.com/mesomap.jpg
so some are working and some are not?
I think I will wait a few days to see if wunderground makes any more changes
is there a xml data feed…for a selected station?
I would say that WD is only picking up on observations around 00 and 06.
As far as I know there’s not any xml feeds for any of the stations.
XML feed for my weather stations is http://api.wunderground.com/weatherstation/WXCurrentObXML.asp?ID=KWVHARPE4
From my site, KMDELLIC3, I see two:
Current Conditions:
http://api.wunderground.com/weatherstation/WXCurrentObXML.asp?ID=KMDELLIC3
Daily Observations:
http://api.wunderground.com/weatherstation/WXDailyHistory.asp?ID=KMDELLIC3&format=XML
And for me:
http://api.wunderground.com/weatherstation/WXCurrentObXML.asp?ID=KMDRELAY1
http://api.wunderground.com/weatherstation/WXDailyHistory.asp?ID=KMDRELAY1&format=XML
a new .zip update of WD is ready now, that uses the XML format now
there is also an updated Ftpupd.exe, as the URL has changed
note, I have lost the arrow images…will try and found them on a back tomorrow…have used some replacements for now…
Thanks for the quick fix. Update is working great! :smiley:
Yep. Looking good. Thanks for the great support Brian.
thanks for the thanks (rare these days)
worked on this until 11pm on a sunday night
I think the arrows have been missing for a while…will see if I can find the original images…
