Can i use this software with my weather station WS-2300-11 together (comport1) with 5pcs 1-wire tempsensors DS18S20 on comport2
Today i use 2 different softwares but can this software handle both?
Yes, you can use a WS2300 & 1-Wire sensors.
Here’s the FAQ about setting up a 1-Wire lightning sensor with another station but the setup is the same for using the temp sensors: 1- Wire Lightning Detector Installation
Just be sure to enter the sensors in order they appear in the list under Dallas Main as #1 Extra temp, #2 Extra temp, etc. You can print that window list off too I believe.
TokKiwi
