Weather reports / warnings via email
I have tried many times to get this function working on my mac but I can never get it to work. I have had it working on the windows version. I use the same settings on the MAC version but it never sends the emails, it generates the reports but thats it. Is there anything I could possibly be doing wrong?
what shows when you try to run the cronemail in a terminal window
It appears as though everything works but on the terminal window it says email failed to send. I
This is what’s on the terminal window
Cronemail.pdf (69.6 KB)
I will do some testing here (using my own email server, etc)
I have tested here and it does work with my email
what type of email server?
does it need secure, etc?
what port number?
Its an imap server and I
I
do you mean its ssl ?
(the more information you can provide the better)
Yes I
I use the Auth option (not ssl) and that works
I would need to add support for SSL email
I would need your email settings (email me those)
I
I have improved /fixed this in the latest update
