I have set up WD to use custom icons, but there are times and places where the standard WD icons appear instead.
Normally, the summary.gif and Chesler.gif and metar2.gif through metar6.gif pictures use the custom icons. Except when it is raining, stopped raining, etc. Then I get the WD standard icons.
Also, it seems that metar.gif, the “primary” metar always uses the WD standard icons.
Is there a problem or have I missed a setting somewhere?
there must be rain icon in wd that is not updated by when you use your own icons
under input daily weather, do you have that wd rain icon visible at all?
Give credit where credit is due… CarterLake created those icons. Now everyone has to go back and make 3 more for these newly defined conditions.
BTW - I can not open the “Windy Rain” icon. (I am using VNC from work but…) When I mouse over it, there is no description popping up, and when I double click on it, no file window opens.
