weather display
My current conditions have stop updating but but I’m still showing that date is being received also time and date are all correct what could have happend I checked all setting and they all seem good and all connections. I have a ultimeter 2000 with a weather picture that is receiving the info correct any help out there thanks
is WD set for complete record mode?
is the data received counter flashing?
have you tried restarting WD?
I also assume you are using a Y connector?
yes im set on complete record mode and yes the received data is flashing and i have restarted wd if a y connecter is the same as a spitter yes one goes to the weather picture and the other to the com port 1
what is the barometer reading showing on the console?
(make sure that has been acitivated)
you were absolutely right Thanks so much
