Weather Display with UI-View
Not sure if this is the corrext group or forum.
The issue is that I can see wx display updating the wxnow.txt and placing it in the correct directory. I have ui-view set to pull it form that location. I set my Max age to 0. But ui-view will not fire the weather wxnow.txt.
Mike
I have mine set to 15 minutes, not zero and it works fine … Try using a higher value?
Cheers
Ian vk2him
