Weather display showing huge rainfall from weatherflow tempest
I updated t the latest version of WD yesterday. My tempest has recorded 0.9mm today which is correct but WD has added more rain every minute since 0800 today, (it was ok overnight showing 0.0mm which was correct) so far in WD is showing over 225mm for today!! Anyone else having issues? all the other readings, temp, wind etc are showing correctly on both Tempest and WD
Edit at 2305. I have now turned WD off as it kept adding between 5 and 10mm of rain EVERY MINUTE so by 2300 it was showing over 2500mm for the day!! My weather station (weatherflow tempest shows 4.5mm, which is correct) all the other readings are correct. I have no idea where WD is getting this rain data from Idon’t get that much rain in a whole year!!
do you have set in WD to use cloud rain
in the weatherflow setup?
No just checked and “cloud daily rain total” box is unticked as is “calculated daily rain total” I’ve been using the tempest for over a year and not changed any settings since setting it up. I did update WD so are these new settings in WD
OK so I’ve now ticked the use “calculated daily rain total” box and that seems to have stopped the ridiculous increases. We are expecting rain tomorrow so lets see if its worked.
