weather display not response
Good morning everyone, my name is Luca I come from Milan in Italy.
I wanted to report a problem with weather display.
Every time I try to change a setting, the program fails to work properly (it says NOT RESPONSE). I bought it almost a year ago and I’ve been looking for solutions but nothing to do.
I use windows 10 as my operating system.
I look forward to further support.
Thank you very much
Luca.
it might be a permission problem
where do you have WD installed to and running from?
what weather station type?
WD I installed it in the root directory of the pc (/C:).
It also has the permissions to run.
The station I use is the Davis Vantage Pro2. (Wired)
I had the same problem with my old PCE-fws-20 station.
ps: I forgot to tell you that windows 10 and 64bit.
Luca
win10 and 64 bit should be OK
so you have it installed to c:\wdisplay ?
(i have not seen it been shown as /C: before?)
have you tried right mouse click, run as adminstrator?
Yes, I have installed it in the main folder of the pc.
and I have run the program as administrator; but nothing to do.
To make you understand better I sent them an email to his address with a video where I showed you how it behaved exactly WD.
my email is: [email protected].
Try to check if it arrived to you.
Luca
i see from the video that you have set WD to get data from weatherlink.com ?
yes exactly.
However, it has always given me this problem even with the old station. as you have seen I struggle to set the various adjustments.
WD gets the new data from weatherlink.com every minute, on the minute
is that when its not responding?
if so, I can set that to be its own thread
It freezes every 10 seconds. Regardless if I send the data online or not.
For example: setting up WD from the old station to the current one took me a while.
that doesn’t sound right
I do notice though that you are on an older build
but did you say it has always been like this for you?
Yes, that’s right.
I thought that anyway after the update it was solved but everything remained the same.
I have also tried to find a patch that was released that would solve this problem, and I have searched in various topics.
And finally I exposed the problem.
if you could email me your settings files (see the FAQ on how to do that)
then I will try here
Good evening I sent him the files with the WD settings just now.
Regards luca
I see the problem
you have just about every internet function set to be updated every 30 seconds
in the customise internet and file creation setup
which is overkill
do you really need all these functions (i.e all set to green, both pages, set to update every 30 seconds, when a lot of the data only updates slowly/daily etc
I would unset the every 30 seconds and every minute settings
then set to update the files /images you really need updated on your web site to be updated and uploaded say every 5 minutes for say the graphs, then every 10 minutes for other things,.,
and only daily for things where the data only changes daily or slowly (e.g moon details etc), detailed climate data, etc
via the individual set times to create and set times to upload
