How easy or hard is it to use Weather Display to build a weather web site?
I have never created a web site before. I want to create a page and update
it with weather information. How easy or difficult would this be to do with
Weather Display?
WD can create and upload a web page for you as noted in this FAQ:
There are also templates available you can use to create a full weather web site:
You’ll also need some server space to host your pages. Normally you get some free webspace with your ISP which will be enough for the basic WD pages. Or, if you really get into it then you can go for your own URL and get someone to host the site for you.
I’m not sure which hosting sites are the best/cheapest in the U.S but I’m sure others on here will be able to give you some info if you want to go down that route.
I asked the same question a couple of weeks ago (before I downloaded WD) and was told ‘no sweat’ - ROFL.
Must be true because I managed to create a website using the Carterlake template and with no prior HTML skills(www.kahurangi.org).
You will find that you are heavily dependant on help from this forum - as the WD documentation is a bit disjointed and often refers to earlier versions - but providing you have a sense of humour
oh yes, a sense of humour goes a long way:wink:
