I thought you used to be able to change the style/type of dials/thermometers etc on the weather dials page. I cant remember how to do this, or what area I should go to - any one able to point me in the right direction?
Cheers
Rob
Cheers
Rob
you can set to show rain funnels
in the colour setup, dials setup
the other option, to display temperature dial on the weather dials, is just as obscure: its in the advanced/misc setttings, temp/hum tab
I will add those options to the right mouse click options on the weather dials actual screen
Brian,
I thought that in the past you were able to change the style of the dials etc for temperatures etc on weather dials page, and could show the max and min as well. Cant you do that any more or am I confusing this with something else?
Rob
you can set to show a temperature gauge that has max/min
instead of the temperture dial
as I posted above
i.e setup, advanced/misc, temperature/humidity tab
(i.e do not have set to display temperature dial on weather dials)
I have added that option and the funnels for rain gauges, as options via right mouse click on the weather dials screen now to the latest .zip update
Loaded the zip file, I see the thermometer graphics for temp, but dont see any indication of max/min on them with the exception of the graphic for wind chill depression.
Rob
the new component used does not have the ability to show the hi/lo markers
you will need to instead use vers 10.37P build 44
Brian,
Ok - I would much rather have all the functionality in build 78 - the ability to have hi/lo markers is not important enough to me to go back to build 44 -so will continue to move forward with the way you are going with this superb product.
Cheers
Rob
you are the first person to even notice they are not there anymore…
Well there you go Brian! I guess that means we have so many features now that we dont notice if some of them get retired.
Cheers
