WDliveapp / URL of clientraw.txt
Under setup and send data to WDliveapp then enter URL to your clientraw.txt file to use when you are away from home - would this be the same as shown in FTP/internet setup, tab connections, under FTP Host/Server and Remote Directory??
If not where do I find this URL?
Nick
Nick,
I found this clientraw file on your site:
http://weatherinyate.x10host.com/weather/clientraw.txt
However it appears to be outdated 16/7/2015
You would want to check your settings under Control panel - Web Files/Web Page - Real Time Client FTP and make sure you are uploading the file routinely.
Also note you may want to add an index file to your http://weatherinyate.x10host.com/weather/ directory…
Thanks for that Bob. I had it working a while back but changed my PC and can’t seem to get it going again.
How do I add the index?
I started the real time FTP, that was set to off?
Still not sure what URL to put in?
Nick
the URL :slight_smile:
as for an index page. Save this code as index.htm or index.html and FTP to your weather directory.
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=windows-1252">
<meta http-equiv="refresh" content="0;url=http://weatherinyate.x10host.com/weather/yate-weather.htm">
<title>Redirecting to main weather page</title>
</head>
<body>
</body>
</html>
Thanks Martyn, again!
Do I create a new folder at the top/home directory and put that code in it?
Same directory that yate-weather.htm is in
because at the moment as Bob says http://weatherinyate.x10host.com/weather/ results in a directory list of all your files.
Actually that file can also go into the home (parent of /weather/) directory as http://weatherinyate.x10host.com/ also gives a directory listing.
Humm can’t get the app to work outside of my local wifi.
Looking at the FTP log clientraw.txt is not being uploaded?? Even though I have YES in setup and entered the URL
is the clientrawrealtimeftp.exe program running and uploading the clientraw.txt file to your web site?
I have WD send tether data vers 1.8 running, is that the same thing? That says “sending, argument out of range, can’t send”
Do I have to set Real Time FTP/WDL switch to ON? When I have tried this before it upsets my free web host company and they suspend my account!
