WDLive (ver 60) not showing rain rate
I have been playing around with WDliveapp and on both clientraw.txt and mqtt the app on the alternate display does not show or indicate the current ra
te.
<clientraw.txt>
12345 1.9 3.9 135 21.5 92 1006.0 19.8 113.7 544.8 0.07 3.79 31.0 …
As you can see on the clip of clientraw.txt, the rain rate (mm/hr) is being included
The rain rate is not included on the “white” default display and shows 0.0 mm/hr as displayed on Rainfall block.
Is there a way to include the rain rate (mm/hr) in the clientraw.txt or can you modify the alternate display to display Rain Rate mm/hr as displayed in clientraw.txt / mqtt
this is the Android version?
yes it is android
i see what is wrong and I will see about updating it
Finally got some rain, after a fair run.
Update worked great.
cheers.
