Dear Team,
I suddenly get seriam number error,
while the site is online since 2002 and never had any issue
I didn’t change anything on my site the last half year
please advice
or
https://www.walschap.net/weer/wx/wx.php
kind regards!
J
Dear Team,
please advice
or
kind regards!
J
Your provider changed your http site to https
If you click your site url above your will end at https://www.walschap.net/weer/wx/wx.php
Therefor the WDL FLASH script needs to be updated.
Download a new version and probably the problem is gone.
indeed, I’ll ty to fix this, subtile issue … didn’t see it. I’ll keep you posted !
make sure to update any URL’s in the .xml and .html code to include the https instead of http
Hi team,
considering same issue, after exactly 1 year, … unfortunately,
[quote author=FTK link=topic=65158.msg536058#msg536058 date=1527843536]
Hi team,
Hi Wim,
it might be the java, but I have here at home an other PC, I tried there, all browsers work???
I know it has to do something with the HTTPS
Indeed you are also right, but go to my page, click on mesomap, then you get the possibility to allow adobe flash player
go back to "waarnemingen " and it works…
UNTIL
I typed the adres with HTTPS and suddenly he wouldn’t start anymor: the serial issue errror
when I type in my browser without, the broswers revers to https and it doensn’t work any more
Is there something in the script I could alter to provoque an always working weather display live panel?
My chrome is V66, Firefox v60, ie Edge latest and IE also latest version 11.48
please advise
If you are using HTTPS
Then make sure to adjust any references to HTTP to https
In the. Html and. XML files
Hi. As mentioned. I Tried that yesterday already without success. I then reverted to the original situation, since that had always worked. I 'll try to adapt the xml and html and php content http to https again.
