After some difficulties with WD and WDL, derivated from a poor station producing data spikes and errors that exceeds WD correction possibilities (and also no other software does), I decided to write a custom program to handle the situation. Finally I could implement a clientraw.txt generation and WDL is again online:
http://www.meteopallars.com (Catalan)
http://wx.meteopallars.com (English)
Since I did make the script based on old documentation, the latest WDL version I can use is v4, my fault!
There are some differences to the standard WDL:
the weather icon shows the Zambretti local forecast
the embedded webcam alternates with the stormtracker map if there are storms detected. By night it alternates a weathermap (generated with digital atmosphere) and the stormtracker map
there are no wind speed and wind direction instruments, since some mountains and buildings don’t allow the correct measure. Only a gust instrument may be from local interest
the refresh time is only 60 seconds, since the station cannot transmit at a higher rate
