WD & WTX536
I’ve got WD hooked up to a Vaisila WTX536 and things like temperature work fine, but I get no updates for wind speed or barometric pressure. The debug screen shows it is getting the correct data from the station. but that data doesn’t seem to propagate to the display. I know the 530 series isn’t directly a choice on the station list but the command structure from the 520 is the same as the 530.
I tried adding a custom tag for wind speed and it still showed 0. It seems some of the tags WD is reading are not updating on the display. What am I missing? I’m using 10.37S build 93 on windows 10.
it could be a units problem
post here that debug info
actually clientraw.txt is default name to go there
also try restarting the real time FTP program
Thanks for the reply, here’s a sample of the debug info
Humidity= 21.2P raw
0R0,Dm=039D,Sm=0.2N,Ta=15.4C,Ua=21.2P,Pa=98800P,Rc=4.88M,Tr=-6.9C,Ra=0.0M,Sl=0.000675V,Sr=-0.640865V,Rt=973.0R,Th=16.2C,Vh=0.0N
Humidity= 21.2P raw
0R0,Dm=054D,Sm=0.1N,Ta=15.4C,Ua=21.2P,Pa=98800P,Rc=4.88M,Tr=-6.9C,Ra=0.0M,Sl=0.000675V,Sr=-0.640865V,Rt=973.0R,Th=16.3C,Vh=0.0N
Humidity= 21.2P raw
change the barometer to hpa instead of pa for the output and that will fix the barometer
I cant or I am not sure where the windspeed and humidity data is?
Thanks, when you mentioned it I went and changed the units in the Vaisala to match the units in WD. And it works. It sounds like a simple problem but I tried all kinds of things to make it work.
Obviously the temperature units matched so it worked, as well as the wind direction. It’s all working now
Thank you for the help.
