Following on from my other post about Can’t exit WD by File\Exit, I have finally got around that problem now by a complete uninstall, then a re install.
Now when I use the data logger to get data from say beginning of the Year 2015 Month 1 Day1, then restart WD, it first says looking for data 01/01/2015 or similar, in reality it only gets data from 2 days ago, when the previous problem started.
I don’t know what to do next. 1 problem has been cure but another created.
Oh dear that is bad news for me then. I do have data backups going back a year or so, so is there a way of using them to show more data, however it is done.
Oh dear, no I didn’t have WD daily backups, only occasional ones.
Where do I go in WD to setup daily backups. I have googled it and looked on this site but not seen the relevant answers.
In the FAQ section is says:
You can now also have this done daily automaticly (see under setup, databackup (but some systems do not handle this very well), and the current datafiles and logfiles are also automaticly zipped with this function).
There is no entry for daily backups under setup in ver290
I have never had to uninstall WD so did that process delete the datafiles and logfiles directories? With hindsight you could have copied those somewhere else before uninstalling and then copied them back to the wdisplay directory after reinstalling and your weather data would have been intact.
