I have purchased a Davis Vantage VUE with a data logger connected. It Sends data to Weather link but will not connect to WD via the data logger USB cable.
WD is asking for a Port number but Windows 10 control panel does not show any port numbers. So no data connection seems to be not available.
Any advice please.
Welcome to the forum.
Have you already accessed the VUE using the WeatherLink software? If so, that sets the port into a different state which means that WD can’t access it. There’s a way to reset it if that’s what’s happened.
Edit: Look at this to see if it helps - https://www.youtube.com/watch?v=6c68CmdMKIQ
Yes, it’s running currently on weather link version 6.0.5.
Brilliant, thank you for your help, all running now on com port 5.
