I have 2 minors problems with this version
I will check on the second issue
but the first issue I need more detailed information other than does not work
When I tick the case Humidex appears for just a second and go back to Heat index.
You can see the result just at the top of the attachements in blue.
what I will need is a copy of your settings files…
Where is the settings file ?
See this FAQ.
Done
Tanks
sorry for the delay
I see the problem
you have a conflict of settings
untick , apparent temperature instead of wetbulb
