WD stalls on startup
Hi All,
Recently, when I start WD the initial display comes up but stalls on downloading the data from my weather station. The only way I can get past this is to select “Abort” and then the display fills in but the “Extreme Conditions” are from a couple of days ago.
Have 2 other weather programs (Weather Link & Virtual Weather Station) and both of them aren’t having this issue.
Any ideas? :frowning:
Thanks!!
Davis Vantage Vue with data logger.
Windows 10
Try running a program called CCleaner, (it’s free) and do a registry scrub, it fixed several problems with WD on my W10 PC.
Thanks Terry,
Have had CCleaner for years and use it fairly regularly. Ran it again and nothing changed. Attached a screenshot of the issue; this will stay the way you see it displayed unless I press “Abort”, but will do the same thing again when WD is re-started.
Thanks again
Down load the latest version, close WD check the task bar make sure FTP icon closes. Install latest version, after it finishes start WD.
zeppline,
Thanks for the reply; I had already tried this with no improvement. The problem seems to have resolved itself with the latest Windows update 8O; don’t know what changed or why it affected WD but there it is :D.
Thanks again for your help!
