When does WD update the current lg file, e.g. 92011lg.txt on one’s computer to the September2011.html file found on one’s website? Cannot seem to find this info in the forum.
OR, how do you force this conversion?
Are you referring to this?
http://jaxweather.net/WeatherImages/WD/September2011.htm
If so the first entry (and the file) is created on Day 2 of each month.
Yes. I think I got it partly corrected, but just wondered if the file was updated around midnight daily since if you look at it each day, the last day listed is yesterday. And the file on gets larger, of course.
The file is created on Day 2 and then gets added to each night after midnight…
Thanks, Bob! That should bring my September report up to date.
ADDED Morning of 20th: Problem solved.
