The last several days WD has crashed (locked up) several times. I have been trying to problem solve the issue but decided it was time to post and get other suggestions.
Computer is a Dell Dimension 8300, Pentium 300 with 1 meg of ram. I have used the Windows Task Manager to monitor the CPU usage. At the beginning of the upload CPU usage can go as 100% for 2 seconds and averaged about 60% during the upload. At idle, without the WD webcam software running system stays at apx. 5%. With the WD webcam software CPU usage is apx. 30%.
WD, antivirus and firewall is the only thing running on the computer. I currently use the CarterLake templates (Ajax) version. I upload the first 5 pages every 5 minutes…the others every hour. I do not upload any file on a 1 minute basis. WDL is scheduled to update every 10 seconds. I upload my weather data to CWOP and Weather Underground…rapid fire is turned off.
This morning I decided to turn the WD web camera software off to see if there would be an improvement. System resources were low but I came home to find WD crashed again. I have copied the FTP file for your review:
list of files uploaded*
Uploading C:\Program Files\wdisplay\webfiles\wx.html → index.html
Uploading C:\Program Files\wdisplay\webfiles\wx2.html → wx2.html
Uploading C:\Program Files\wdisplay\webfiles\wx3.html → wx3.html
Uploading C:\Program Files\wdisplay\webfiles\wx4.html → wx4.html
Uploading C:\Program Files\wdisplay\webfiles\wx5.html → wx5.html
Start Time/date:10:20:08 AM 2/23/2007
ncz042.txt
ncz042.txt
Permanent connection selected
Checking for what else to do…
there are 2 more things to do
Wunderground connected status: OK
Wunderground complete
there are 1 more things to do
Aprs data sending now…
APRS Connecting to: rotate.aprs.net
Aprs connected
sending pass command
user W4RJF pass -1 vers wx-display 10.37b 31
Sending the aprs data now
APRS data send:
W4RJF>APRS,TCPIP*:@231520z3532.06N/07834.43W_355/003g006t046r000p000P00
0b10201h32.WD 31
Disconnecting from the aprs server now
APRS disconnected
Finshed email agenda
Finshed email agenda, and more Internet agenda items to do…
Time/date:10:20:14 AM 2/23/2007
Logging onto FTP server…ftp.i40exit319weather.com
Connecting to FTP server.
Connected.
220 Microsoft FTP Service
USER=****
331 Password required for rjford.
PASSWORD=****
230 User rjford logged in.
TYPE I
200 Type set to I.
Checking for next FTP agenda…
Doing ftp upload
Checking there are files to upload
There are more files to upload
PASV
227 Entering Passive Mode (68,178,211,53,13,147).
STOR index.html
125 Data connection already open; Transfer starting.
226 Transfer complete.
PASV
227 Entering Passive Mode (68,178,211,53,13,148).
STOR wx2.html
PASV
227 Entering Passive Mode (68,178,211,53,13,149).
STOR wx3.html
PASV
227 Entering Passive Mode (68,178,211,53,13,152).
STOR wx4.html
PASV
227 Entering Passive Mode (68,178,211,53,13,153).
STOR wx5.html
No more files to upload
All Agenda complete, doing FTP log off…
FTP logoff
QUIT
221
Disconnected.
I have followed the discussion concerning the gdiplus.dll file. I’m a computer light weight so I’m not real sure what this file is suppose to do. I did remove this file from the WD folder.
The current versions of WD is 10.37b build 06. I’m sure I need to provided additional data but I’m unsure of what to include. Thank you for reviewing this post and I look forward to a possible solution.
http://www.i40exit319weather.com/
Ronnie
