Howdy.
My wd-live page shows all other graphs just fine but daily graph never indicates any rain ?
Any ideas ?
thx
Howdy.
Any ideas ?
thx
which version of WD?
which version of WDL?
do you mean the rain last 24 hour graph?
Hey guys !
Yeah I’m running WD 10.37r303, not shure about the wd live version.
It’s the most recent I have found.
Anyways, it’s raining like h*ll at the moment and the 24hr graph shows zero
It has worked before, but has just suddenly stopped showing the graph on 24hr rain…
As said, all the other graphs work just fine.
Any ideas are welcome.
cheers:k
WD does not seem to be putting rain data into your clientrawextra.txt (I think I am right in saying the WDL rain 24 hour graph uses this data).
570 rain hour 21 M 0.0 mm ( = 0 in )
571 rain hour 22 M 0.0 mm ( = 0 in )
572 rain hour 23 M 0.0 mm ( = 0 in )
573 rain hour 24 M 0.0 mm ( = 0 in ) shows the past 4 hours are all zero even though it is raining there.
and you can see mine has rain data
571 rain hour 22 M 0.8 mm ( = 0.031 in )
572 rain hour 23 M 1.6 mm ( = 0.063 in )
573 rain hour 24 M 2.2 mm ( = 0.087 in )
As a first suggestion try downloading and running the latest version of WD to see if it fixes the issue or not and we can go from there.
also, what weather station type?
I got TFA Nexus station.
It has worked before like 2-3 years, now just suddenly stopped showing the 24hr graph…
I will try updating WD.
I’ll get back you when I know the results.
thx for the advice
cheers:k
Edit*)
Actually I noticed that My weather display live is version 6.09
So it’s the latest available. What do You think, should I try to re-install it ?
that is the latest version of WDL
what is the version of WD you are using?
Hi WD.
I’m running 10.37R Build 306 at the moment.
But this problem has persisted now through several versions
cheers:k
I suspect that this problem is related to your weather station type (Irox)
try a new .zip update of WD, ready now
(then see how to goes going forward)
Ok, wilco, thx a thousand.
Will get back to you.
ps: WD has worked before with this station just fine for 2 years or so, it just suddenly stopped to delivering the daily rain data…
Go figure ?
Hi WD.
Sorry it took a while for me to reply since we had freezings temps and thus no rainfall ( have had 30cm of snow though )
I updated WD it’s now running 10.37 r310. My station’s 24h raingraph is back and working as intended!
Many thx for fixing it.
Cheers: k
