WD Lightning Settings for L2K
Can someone remind me where the lightning settings are in WD for L2K, specifically, where you check to play .wav file based on so much activity in a time period. I can’t find those settings, the .wav is going off all the time, and it’s about driven me nuts!
On your WD desktop should be the lightning count… Click on that :slight_smile: Note that the only way to stop the Lightning .wav is to remove/rename it in your main WD directory lightning.wav…
