I think that the receiving data from console accumulated there during period without connect to PC is just “get old data”
Yes, I said about this. Similar problems discussed in http://discourse.weather-watch.com/t/37862
I agree with you. I analyzed your files and found:
- under 1st start WD after repair of PC you have correct date in WDISPLAY.INI (11:55PM 22.01.2010) which more early than time of last received record
WD started to extract history data since 17:24 12Feb to about 19:20 13Feb. Here WD had failure, stopped process and started to receive curent data. You stopped WD
- then you restart WD, but time in WDISPLAY.INI was 16:38 20Feb (!). I think that this time is derective for WD about received records from console and WD used this time for control and rejecting of repeated data.
In “2010-02-20 @ 16h40\wmr200history.txt” we see that WD start to receive the historical data from 19:24 13Feb and stopped on 05:15 15Feb. This show that data set in WMR200 buffer was full without gaps. But (!) this data were got to log file 22010lg.txt.
I think that is bug of WD, but this problem can be partly eliminate under CORRECT time in WDISPLAY.INI. If you change this time to 19:00 13Feb then all data from 19:24 13Feb to 05:15 15Feb were recorded to log file.
then situation repeated, WD received (or control) historical data from console, but didn’t write to log-files, only short fragments
during last restaring time in WDISPLAY.INI was correct (why?) - 06:44 20Feb. After this the data are good.
