WD is corrupting data from WMR200 data logger
I was unfortunately hit by lightning in my office and my computer was down for 8 days.
I’ve had my computer fixed and fortunately I could recover my disk.
Date and time of lightning strike : Fri, 12 Feb 2010 @ 17h24 Date and time of WMR200 data recovery: Sat, 20 Feb 2010 @ 16h00
I had to run WD 8 times in total to get all the data extracted from the WMR200 data logger.
It took me about 3 hours for the data recovery from the WMR200 data logger.
At each step I made a backup of the following:
- wmr200history.txt & programerrorlog.txt etc.
- ./datafiles folder
- ./logfiles folder
If I have a look at the wmr200history.txt files I can see that the WMR200 did send all the data for the 8 days correctly.
It looks like WD history extraction is not joining the data correctly, although correctly send by the WMR200.
Specifically for the data extraction on the 15th Feb at 05:16:00 things started going horribly wrong (see attached history file in folder [2010-02-20 @ 16h40]).
I have attached following files for all 8 runs:
- wmr200history.txt
- programerrorlog.txt
Attached for the last run is:
- logfiles/22010extralog.csv
- logfiles/22010lg.txt
Zip file here: [color=blue][b]http://www.bashewa.com/data/2010-02-20.zip[/b][/color]
If other files are needed please let me know.
I’m also missing the climate data for the whole month of February (see http://www.bashewa.com/wxclimatedata.php).
Brian can you have a look at this problem and possibly recover the data for me please?
Here is a screenshot of my current WD screen.
There’s a notice with an error overlaid on the screen and the icon is also missing.
If you are a WMR200 owner then please add your voice to this thread … the more voices the better.
Edit: I have posted possible solutions over in this post: [color=blue][b]Proposal how to fix this problem[/b][/color]
