Hi, im using WD to display current information along with Weather Forecast (Using a modified version of the Carter Lake Layout). I’ve set the Forecast settings to download for my location and from time to time it does appear on my site, but at different times of the day when i go to my site and look at the place where the forecast information should be is blank, even though there was a forecast text in that same spot a few hours ago.
What setting should i recheck to see if i have the forecast downloading like it should and displaying right?
My site is http://wncw.net
Edit: It just now appeared again after being blank for a while, I didnt do no changes to make it appear again.
Any idea on what option i should change since it appears from time to time and then the place where the forecast goes is blank at other times?
The NWS has a long history (as far as we are concerned) of mucking with the format of Forecasts and even screwing them up completely especially on weekends…
If you note your forecast is missing again check your local forecast text file in your WDisplay directory and see what it contains… If you find you keep having problems you may want to change to using the PHP Forecast script here.
http://discourse.weather-watch.com/p/52376
if the downloaded noaa forecast file is actualy empty in this case, then I can add in maybe a back up feature, i.e use the last one downloaded maybe?
Adding a backup feature would be handy - wdftp has created a new file by the time it gets the error message so the result is a 0 byte file.
(Though one of these days I really should try to get familiar with php and join the modern world).
I would love to have a backup feature. My forecast is blank now, usually does it for a short time every day…
interestingly I’ve had this problem off and on for 20 months or so…sometime it will work for 2 or 3 months and then suddenly start to screw up… Cheked the (in this case ) wyz021.txt file it’s there if I do a manual create and upload sometime it works sometimes not… Then suddenly it will start to parse and upload the file again…??? I am aware that the NWS has who knows working on weekends and quite often you can see their mistakes… Here’s a copy.
Expires:200708261245;;975901
FPUS55 KSLC 252146
ZFPSLC
ZONE FORECASTS FOR UTAH
NATIONAL WEATHER SERVICE SALT LAKE CITY UT
346 PM MDT SAT AUG 25 2007
WYZ021-261245-
SOUTHWEST WYOMING-
INCLUDING…EVANSTON
.TONIGHT…MOSTLY CLEAR. LOWS IN THE LOWER 50S. SOUTHWEST WINDS 10 TO
20 MPH IN THE EVENING.
.SUNDAY…BREEZY. PARTLY CLOUDY. HIGHS IN THE MID 80S. WEST WINDS
15 TO 25 MPH.
.SUNDAY NIGHT…BREEZY. A 20 PERCENT CHANCE OF SHOWERS AND
THUNDERSTORMS. PARTLY CLOUDY. LOWS IN THE LOWER 50S. SOUTHWEST WINDS
15 TO 25 MPH.
.MONDAY…A SLIGHT CHANCE OF SHOWERS AND THUNDERSTORMS IN THE
MORNING…THEN A CHANCE OF SHOWERS AND THUNDERSTORMS IN THE
AFTERNOON. PARTLY CLOUDY. HIGHS AROUND 80. SOUTHWEST WINDS 10 TO
20 MPH. CHANCE OF PRECIPITATION 30 PERCENT.
.MONDAY NIGHT…A CHANCE OF SHOWERS AND THUNDERSTORMS IN THE
EVENING…THEN A SLIGHT CHANCE OF SHOWERS AND THUNDERSTORMS AFTER
MIDNIGHT. PARTLY CLOUDY. LOWS AROUND 50. SOUTHWEST WINDS 10 TO
.TUESDAY…PARTLY CLOUDY WITH A 20 PERCENT CHANCE OF SHOWERS AND
THUNDERSTORMS. HIGHS AROUND 80.
.TUESDAY NIGHT THROUGH SATURDAY…PARTLY CLOUDY. LOWS IN THE MID
50S. HIGHS IN THE LOWER 80S.
