wd fail
hi all
In the last couple of days WD as stopped reading data from the weather station (La Crosse 3650) after working for months. i have updated to 10.37P build 39 i was running build 38, restarted the computer and the weather station a number of times, the green lights at the bottom come on with the data quality light staying on and the other one flashing once then staying off. I have install the heavy weather software to check the link with the weather station which is also working fine updating the heavy weather software.
I havn’t update or changed the computer that it has been running fine
There doesn’t seem to be any error messages
ideas please ???
thanks
Paul
are you using the fetch3600 method?
have tried a reboot of the pc?
Hi Windy
thanks for replying
i have tried it with and without ticked with a restart of the software between them
when it is unticked i get a error of “invalid floating point operation at time/date ( the time the software loads)”
when ticked nothing
i have tried rebooting the pc and weather station a number of times
paul
that error is the root of the problem
download the Debug version and use that
and then post here the WeatherD.elf error file that should get produced when that error occurs (in c:\ )
Hi Windy
file attached as requested
file renamed to .txt to allow uploading
thanks
Paul
WeatherD.txt (23.2 KB)
the error is occuring when WD is trying to read in missed data from the WH1081 station
(make sure that WD is not set to use that station type…actually I think the problem is with the use direct setting in use…untick that…for the WH1081)
try turning off the switch under control panel, data logger setup
then restart WD
the station type is set to la crosse 3600 only
and the data logging is switched off did try switching on but made no diffrence
thanks
Paul
Hi All
any one else got any idea’s
thanks
Paul
did you check that WH1080 direct setting (untick that)
also try the latest build 40 version
windy
where do i find the WH1080 direct setting ???
Paul
in the weather station type setup
but try the latest version, build 40
check in setup and couldnt see it ??
tried release 40 and the same results unticked the "just use the fetch3600 direct program " floating point error
ticked no error but no comms with the weather station
paul
I will get a new debug version build 40 uploaded now for you to try (to get a new error report)
log file attatched as requested for version 40
file changed to .txt
thanks
Paul
WeatherD.txt (23 KB)
getting the same results with version 40 !!!
i want to try reinstalling from scratch what other files are outside the wdisplay that hold the config data as i have tried installing in a new folder but it still picks up the setting
paul
There’s a FAQ describing how to run another fresh/independent install on the same PC.
.zip and email me your settings files
wdisplay.ini and wdisplayftp.reg (after going action, back up registry entry now)
and your history.dat file
and I will test here
hi Brian
Been through all the menus tonight looking for the WH1081 option finally found it unticked it and it is now working ( never been there before don
strangely,even with it ticked, it should not have caused the problem still with the latest version update
