Hi. I would be grateful if you know of a way to add the value of ET on the data that WD transmits via API to Meteotemplate. Thank you
A wild guess: do you have the Control Panel > Solar Sensor main switch turned on in WD?
Hi Bitsostring. But of course, WD is fully configured with all its options including the solar sensor. The fact is that Meteotemplate is a model that has been left to itself for a few years, but for the most part it still works. It should also be considered that the creator on his declaration is working for an upgrade. For the moment on the internet there are updates, APIs, blocks, plugins, with which you can manage more data including the ET. This is where WD comes in, which is perfect for the original Meteotemplate model but not for the unofficial updates mentioned above. And that’s why I was wondering if anyone knows how to modify and include data like ET on WD’s pre-existing API. I tried to set it with realtime.txt and a cronjob that contains much more data, but I could not configure it. Again, I wonder if anyone has found a way to make it work this way.
