Is there a document that details the format of data coming in on the RS232 port? I have a Campbell Scientific CR300 data logger and have written a control program for it that outputs sensor data in any format. I want to connect this to WD to archive the data and display the real time weather conditions.
I should add that what I am looking for is the ‘generic’ format used by WD to receive weather data from a sensor(s). I can format the output of the data logger into any string but prefer simpler formats over complex formats to reduce coding time. I have seen several references in this forum to the equipment interface using the WD format, but I cannot find that documented anywhere. If there is no ‘generic’ format then which of the supported station data formats would be the simplest to emulate? In other words, I could make the CR300 data logger look like a Davis Vue or LaCrosse station. I suspect though that those formats are rather complex.
You could try writing the data into a file formatted as clientraw.txt and setting WD in Stationless mode and reading the clientraw.txt file. See http://discourse.weather-watch.com/p/75066 for some details on how to set this up.
I looked at the ClientRaw description and feel that is way too complex for what I need. Maybe the station emulator is the solution. For example, if there is one of the supported stations that simply sends data to WD in single lines like this:
T 23.7 CR LF
where T is temperature, or multiple data per line like this:
T 23.7, P 1023.4, H 87.3
where T is temperature, P is pressure and H is humidity.
I think you can use stationless mode with METAR input which might be simpler but I don’t know if the METAR format has all the data values you need to send.
