I have been trying for a long while now (off and on) to get my data to upload to the FundU site You guys have helped me get it going when I used the CWOP ID but I am now using my HAM ID. Below is the results from the CWOPlogsend.txt file.
CWOP data send start 11:00:01 AM 7/12/2023
*APRS Connecting to: cwop.aprs… * Aprs connected sending pass command user KK4OHF pass 17568 vers wx-display 10.37S148 Sending the aprs data now APRS data send: * KK4OHF>APRS,TCPIP:@121500z3347.31056N/08454.42069 6W_150/002g003t084r000p000P000b10142h68.WD 10 Disconnecting from the aprs server now Finished
Here is what I get from the FindU site.
Sorry, no weather reports for KK4OHF…
Attached are screen captures from WD/CWOP setup page.
I am using rotate.aprs… on port 14580 but the default sticks with cwop.aprs…
I’ve also played with the Validation number of -1 but this doesn’t help. All test sends fail. FTP is enabled as the note states but I am not sending any other data via FTP…
I haven’t used CWOP for a long time so I’m way out of date about it. My only thought is do you have the Main Internet switch turned on? That’s on another page so not quite so obvious to see. If you’re doing other uploads then you probably do have it turned on, but worth checking just in case.
So today I sent NOAA another email asking for their assistance. Their website has options for either a new account or updating an existing. When I select new, it responds that my call sign is already in use. When I select update it says it cannot find my call sign in their database.
It sure seems that the governments sole job is to confuse and complicate things for its citizens…
The good news is my data is now showing on CWOP/FindU once again. I finally got someone from NOAA to update my location information and email address. Only they can update an ID or email address. All my data started showing up as advertised!
