WD Crashing Log
Currently running the latest version but, I’ve tried several versions and it doesn’t matter
Computer
Athlon 1.3
1 gig of ram
60 gig hard drive
windows xp pro service pack 2
ERROR: Access violation at address FFFF0000. Read of address FFFF0000 at time/date 9:00:41 AM 12/28/05
Above error or program log occured at :9:00:41 AM 12/28/05
ERROR: Access violation at address FFFFFFFF. Read of address FFFFFFFF at time/date 9:00:41 AM 12/28/05
ERROR: Access violation at address FFFF0000. Read of address FFFF0000 at time/date 9:00:42 AM 12/28/05
Above error or program log occured at :9:00:42 AM 12/28/05
ERROR: Access violation at address FFFFFFFF. Read of address FFFFFFFF at time/date 9:00:42 AM 12/28/05
i assume you have , use 9am reset, option in use (i.e because you live in australia)?
i.e its something happening at 9am reset that is causing a problem
maybe try running the debug version at at 9am watch and then there should be a detailed error report generated and post here the different tab sections of that report (use the copy to clipboard function)
note that i am away on holiday still,not back until the weekened
I’ve not changed any settings. i live in the US, California. Here is the latest crash log. It crashes when I open up WD from the task bar, then it creates the log for that time.
ERROR: Access violation at address 00800004 in module ‘WeatherD.exe’. Read of address FFFFFFFF at time/date 11:02:49 AM 12/28/05
Above error or program log occured at :11:02:49 AM 12/28/05
ERROR: Access violation at address FF011801. Read of address FF011801 at time/date 11:02:49 AM 12/28/05
I have checked high and low for settings changes. I don’t have an pre-set, reset times. When I double click on the Temp in the task bar, weather display opens up on my desk top and then goes into the error mode and the following errors are logged.
ERROR: Access violation at address FFFF0000. Read of address FFFF0000 at time/date 9:02:20 AM 12/29/05
Above error or program log occured at :9:02:20 AM 12/29/05
ERROR: Access violation at address FFFF0000. Read of address FFFF0000 at time/date 9:02:21 AM 12/29/05
Above error or program log occured at :9:02:21 AM 12/29/05
It’s also nice to have a no-working weather web page that you’ve worked hard on.
Latest crash codes: I’ve turned off so many things in my weather dispaly program and deleted WDlive thinking that’s what has caused the problem. I’m doing research on other weather software that doesn’t change all the time
does the debug version give any more information?
note that I am going to work on a couple of things that will help:
1:), option to restart the program if x number of access violations occur in a row
2:) split wd up into a logging .exe and a web update .exe and a data viewer.exe
but from your lat post it sounds like you are ready to throw in the towel
good luck for the future and sorry for all your problems
Above error or program log occured at :3:14:14 PM 12/29/05
ERROR: Access violation at address FFFFFFFF. Read of address FFFFFFFF at time/date 3:14:14 PM 12/29/05
ERROR: Access violation at address FFFF0000. Read of address FFFF0000 at time/date 3:14:14 PM 12/29/05
ERROR: Access violation at address FFFFFFFF. Read of address FFFFFFFF at time/date 3:14:26 PM 12/29/05
Above error or program log occured at :3:14:26 PM 12/29/05
ERROR: Access violation at address FFFF0000. Read of address FFFF0000 at time/date 3:14:26 PM 12/29/05
ERROR: Access violation at address FFFFFFFF. Read of address FFFFFFFF at time/date 3:14:28 PM 12/29/05
Above error or program log occured at :3:14:28 PM 12/29/05
ERROR: Access violation at address FFFF0000. Read of address FFFF0000 at time/date 3:14:28 PM 12/29/05
ERROR: Access violation at address FFFFFF01. Read of address FFFFFF01 at time/date 6:15:04 PM 12/29/05
Above error or program log occured at :6:15:04 PM 12/29/05
ERROR: Access violation at address FF00007F. Read of address FF00007F at time/date 6:15:04 PM 12/29/05
ERROR: Access violation at address 0041B8E4 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 6:16:03 PM 12/29/05
Above error or program log occured at :6:16:03 PM 12/29/05
ERROR: Access violation at address 0041B8E4 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 6:18:02 PM 12/29/05
Above error or program log occured at :6:18:02 PM 12/29/05
ERROR: Access violation at address 0041B8E4 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 6:20:02 PM 12/29/05
Above error or program log occured at :6:20:02 PM 12/29/05
Resetting wind/temperature daily value , day: 30
Above error or program log occured at :12:24:20 AM 12/30/05
Resetting rain daily value , day: 30
Above error or program log occured at :12:24:21 AM 12/30/05
Above error or program log occured at :12:25:52 AM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 10:12:05 AM 12/30/05
Above error or program log occured at :10:12:05 AM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 10:13:02 AM 12/30/05
Above error or program log occured at :10:13:02 AM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 10:14:02 AM 12/30/05
Above error or program log occured at :10:14:02 AM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 10:15:01 AM 12/30/05
Above error or program log occured at :10:15:01 AM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 10:16:03 AM 12/30/05
Above error or program log occured at :10:16:03 AM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 10:17:03 AM 12/30/05
Above error or program log occured at :10:17:03 AM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 10:18:03 AM 12/30/05
Above error or program log occured at :10:18:03 AM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 10:19:03 AM 12/30/05
Above error or program log occured at :10:19:03 AM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 10:20:03 AM 12/30/05
Above error or program log occured at :10:20:03 AM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 10:21:02 AM 12/30/05
Above error or program log occured at :10:21:02 AM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 10:22:02 AM 12/30/05
Above error or program log occured at :10:22:02 AM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 10:23:03 AM 12/30/05
Above error or program log occured at :10:23:03 AM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 10:24:02 AM 12/30/05
Above error or program log occured at :10:24:02 AM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 10:25:01 AM 12/30/05
Above error or program log occured at :10:25:01 AM 12/30/05
ERROR: Access violation at address FFFFFFFF. Read of address FFFFFFFF at time/date 10:25:49 AM 12/30/05
Above error or program log occured at :10:25:49 AM 12/30/05
ERROR: Access violation at address FFFF0000. Read of address FFFF0000 at time/date 10:25:49 AM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 2:14:05 PM 12/30/05
Above error or program log occured at :2:14:05 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 2:15:01 PM 12/30/05
Above error or program log occured at :2:15:01 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 2:16:02 PM 12/30/05
Above error or program log occured at :2:16:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 2:17:02 PM 12/30/05
Above error or program log occured at :2:17:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 2:18:02 PM 12/30/05
Above error or program log occured at :2:18:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 2:19:02 PM 12/30/05
Above error or program log occured at :2:19:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 2:20:02 PM 12/30/05
Above error or program log occured at :2:20:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 2:21:02 PM 12/30/05
Above error or program log occured at :2:21:02 PM 12/30/05
ERROR: Access violation at address FFFFFF00. Read of address FFFFFF00 at time/date 2:21:06 PM 12/30/05
Above error or program log occured at :2:21:06 PM 12/30/05
ERROR: Access violation at address FF00007F. Read of address FF00007F at time/date 2:21:06 PM 12/30/05
does running the debug version give any more information?
i am a bit perplexed about your statement about the program always changing, when in the past when you have had trouble and you have emailed for help, it is something that you have setup or done wrong (e.g like with the web cam)
note that alot of those errors are old errors…i.e try deleting the file programerrorlog.txt to start it fresh
I have turned everything off that I can think of on WD, I’m not uploading anything other than my wx web files 1-10. I’ll start a brand new program log and send you the data when it crashes. I go to open WD by double clicking the degree number in the task bar. The main WD screen will then open on my desk top. A program error window will then pop up and have following written on the box or window.
WeatherD.exe has generated errors and will be closed ny windows. You will need to restart the program. An error log will be generated.
I have literally turned off everything that I can think of and I’ve double checked the on/off switches to make sure that isn’t causing a problem… I don’t use the Web Cam feature or any of the other features but, I went through everything to double check that it wasn’t even clicked. The only thing that I have ticked is the ftp upload #-o
10.31 f is the version.
you can check that program log before bringing up to view…
note that when i mean the debug version, thats different to checking the program error log…
i mean to run the debug version (download that) and see what the reports (it should bring up a detailed error report)
I’m running the debugged version so I guess I don’t know how to view that error log. It does not come up automatically. So, for the time being until i can learn how to view the debugged version here is the latest error log/
ERROR: Access violation at address FFFFFFFF. Read of address FFFFFFFF at time/date 5:14:54 PM 12/30/05
Above error or program log occured at :5:14:54 PM 12/30/05
ERROR: Access violation at address FFFF0000. Read of address FFFF0000 at time/date 5:14:54 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:15:03 PM 12/30/05
Above error or program log occured at :5:15:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:16:03 PM 12/30/05
Above error or program log occured at :5:16:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:17:02 PM 12/30/05
Above error or program log occured at :5:17:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:18:03 PM 12/30/05
Above error or program log occured at :5:18:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:19:03 PM 12/30/05
Above error or program log occured at :5:19:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:20:02 PM 12/30/05
Above error or program log occured at :5:20:02 PM 12/30/05
ERROR: Access violation at address FFFFFFFF. Read of address FFFFFFFF at time/date 5:20:03 PM 12/30/05
Above error or program log occured at :5:20:03 PM 12/30/05
ERROR: Access violation at address FFFF0000. Read of address FFFF0000 at time/date 5:20:03 PM 12/30/05
ERROR: Access violation at address FFFFFFFF. Read of address FFFFFFFF at time/date 5:20:04 PM 12/30/05
Above error or program log occured at :5:20:04 PM 12/30/05
ERROR: Access violation at address FFFF0000. Read of address FFFF0000 at time/date 5:20:04 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:21:03 PM 12/30/05
Above error or program log occured at :5:21:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:22:03 PM 12/30/05
Above error or program log occured at :5:22:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:23:03 PM 12/30/05
Above error or program log occured at :5:23:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:24:02 PM 12/30/05
Above error or program log occured at :5:24:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:25:01 PM 12/30/05
Above error or program log occured at :5:25:01 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:26:02 PM 12/30/05
Above error or program log occured at :5:26:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:27:02 PM 12/30/05
Above error or program log occured at :5:27:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:28:02 PM 12/30/05
Above error or program log occured at :5:28:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:29:02 PM 12/30/05
Above error or program log occured at :5:29:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:30:01 PM 12/30/05
Above error or program log occured at :5:30:01 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:31:03 PM 12/30/05
Above error or program log occured at :5:31:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:32:03 PM 12/30/05
Above error or program log occured at :5:32:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:33:03 PM 12/30/05
Above error or program log occured at :5:33:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:34:03 PM 12/30/05
Above error or program log occured at :5:34:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:35:01 PM 12/30/05
Above error or program log occured at :5:35:01 PM 12/30/05
ERROR: Access violation at address FFFFFFFF. Read of address FFFFFFFF at time/date 5:35:02 PM 12/30/05
Above error or program log occured at :5:35:02 PM 12/30/05
ERROR: Access violation at address FFFF0000. Read of address FFFF0000 at time/date 5:35:02 PM 12/30/05
ERROR: Access violation at address FFFFFFFF. Read of address FFFFFFFF at time/date 5:35:03 PM 12/30/05
Above error or program log occured at :5:35:03 PM 12/30/05
ERROR: Access violation at address FFFF0000. Read of address FFFF0000 at time/date 5:35:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:36:02 PM 12/30/05
Above error or program log occured at :5:36:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:37:02 PM 12/30/05
Above error or program log occured at :5:37:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:38:02 PM 12/30/05
Above error or program log occured at :5:38:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:39:02 PM 12/30/05
Above error or program log occured at :5:39:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:40:02 PM 12/30/05
Above error or program log occured at :5:40:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:41:03 PM 12/30/05
Above error or program log occured at :5:41:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:42:03 PM 12/30/05
Above error or program log occured at :5:42:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:43:03 PM 12/30/05
Above error or program log occured at :5:43:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:44:03 PM 12/30/05
Above error or program log occured at :5:44:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:45:01 PM 12/30/05
Above error or program log occured at :5:45:01 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:46:03 PM 12/30/05
Above error or program log occured at :5:46:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:47:02 PM 12/30/05
Above error or program log occured at :5:47:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:48:02 PM 12/30/05
Above error or program log occured at :5:48:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:49:02 PM 12/30/05
Above error or program log occured at :5:49:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:50:02 PM 12/30/05
Above error or program log occured at :5:50:02 PM 12/30/05
ERROR: Access violation at address FFFFFFFF. Read of address FFFFFFFF at time/date 5:50:02 PM 12/30/05
ERROR: Access violation at address FFFF0000. Read of address FFFF0000 at time/date 5:50:02 PM 12/30/05
ERROR: Access violation at address FFFFFFFF. Read of address FFFFFFFF at time/date 5:50:03 PM 12/30/05
Above error or program log occured at :5:50:03 PM 12/30/05
ERROR: Access violation at address FFFF0000. Read of address FFFF0000 at time/date 5:50:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:51:02 PM 12/30/05
Above error or program log occured at :5:51:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:52:03 PM 12/30/05
Above error or program log occured at :5:52:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:53:03 PM 12/30/05
Above error or program log occured at :5:53:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:54:03 PM 12/30/05
Above error or program log occured at :5:54:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:55:02 PM 12/30/05
Above error or program log occured at :5:55:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:56:03 PM 12/30/05
Above error or program log occured at :5:56:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:57:03 PM 12/30/05
Above error or program log occured at :5:57:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:58:02 PM 12/30/05
Above error or program log occured at :5:58:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 5:59:02 PM 12/30/05
Above error or program log occured at :5:59:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 6:00:02 PM 12/30/05
Above error or program log occured at :6:00:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 6:01:03 PM 12/30/05
Above error or program log occured at :6:01:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 6:02:02 PM 12/30/05
Above error or program log occured at :6:02:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 6:03:02 PM 12/30/05
Above error or program log occured at :6:03:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 6:04:03 PM 12/30/05
Above error or program log occured at :6:04:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 6:05:01 PM 12/30/05
Above error or program log occured at :6:05:01 PM 12/30/05
ERROR: Access violation at address FFFFFFFF. Read of address FFFFFFFF at time/date 6:05:02 PM 12/30/05
Above error or program log occured at :6:05:02 PM 12/30/05
ERROR: Access violation at address FFFF0000. Read of address FFFF0000 at time/date 6:05:02 PM 12/30/05
ERROR: Access violation at address FFFFFFFF. Read of address FFFFFFFF at time/date 6:05:03 PM 12/30/05
Above error or program log occured at :6:05:03 PM 12/30/05
ERROR: Access violation at address FFFF0000. Read of address FFFF0000 at time/date 6:05:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 6:06:03 PM 12/30/05
Above error or program log occured at :6:06:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 6:07:03 PM 12/30/05
Above error or program log occured at :6:07:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 6:08:03 PM 12/30/05
Above error or program log occured at :6:08:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 6:09:03 PM 12/30/05
Above error or program log occured at :6:09:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 6:10:02 PM 12/30/05
Above error or program log occured at :6:10:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 6:11:02 PM 12/30/05
Above error or program log occured at :6:11:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 6:12:02 PM 12/30/05
Above error or program log occured at :6:12:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 6:13:02 PM 12/30/05
Above error or program log occured at :6:13:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 6:14:02 PM 12/30/05
Above error or program log occured at :6:14:02 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 6:15:01 PM 12/30/05
Above error or program log occured at :6:15:01 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 6:16:03 PM 12/30/05
Above error or program log occured at :6:16:03 PM 12/30/05
ERROR: Access violation at address 0041AF60 in module ‘WeatherD.exe’. Read of address 00000010 at time/date 6:17:03 PM 12/30/05
Above error or program log occured at :6:17:03 PM 12/30/05
Disregard the last comment, I wasn’t running the debugged version. Just downloaded it and I’ll give it a try. Sorry for the error on the version
i think adding the option to restart wd if x number off access violations occur will be a good option for you to have…
(as it could be any number of things causing it (e.g virus scanners, screen savers, etc)
could you test a test version of that for me?
Sure but i don’t have any virus scanners enabled or screen savers enabled. You would not believe how much I’ve shut down this past week to include removing software just to narrow down things. I’m looking for the restart feature and it will take a bit to find
Great, now my web server ns1.brantservers.com is not responding or down. Perfect timing and no notifications from the keeper of the server.
I was having this same problem… after a little research, I just recently disabled “Indexing Service” in Win XP (Administrative Tools/Services) and this problem has seemed to stop for me.
thats an intereseting find Rick…as , yes, i remember you did seem to get that error alot, and i was always scratching my head why!
the restart feature is in the ftp/internet setup, reboot setup…
I’ll give the indexing a try, mine was set on manual so I disabled the feature, Brian here is the latest errorlog and I’ll do what you ask. I’m off to bed
301: Interrupted.
Above error or program log occured at :9:06:48 PM 12/30/05
ERROR: Access violation at address 007A15DD in module ‘WeatherD.exe’. Read of address 8D2D06B7 at time/date 11:16:45 PM 12/30/05
Above error or program log occured at :11:16:45 PM 12/30/05
301: Interrupted.
that means you have WD doing internet tasks, like say clientraw downloads for client data or real time mesomap data or similar i think you have something setup you should not... email me your settings files and i will have a look
I’ll need help finding the settings files, if you don’t mind, thanks
