WD barometer graph flatlined at 1013.2
Hi, seasons greetings to all.
After struggling with WD in a Parallels installation I gave up and last night did a fresh install on my Windows machine. Now my barometer graph has flatlined at 1013.2, which if I remember correctly is the default barometer reading on install before any new data. I take a data feed from WU. The data on WU appears to be correct and there is certainly baro variation in the WU data tables. They also seem to agree to the baro reading on my Acurite console (which feeds WU). In the WU CSV download, the baro reading from WU seems to be 1040. I’m tempted to delete all my data files and download them again from WU but I sense there is something else I should be doing.
The actual baro reading for all this time was around 1016 and bounced around as we had a storm so the WU data is all nonsense.
Any ideas?
I should add that the baro reading in “Current Conditions” is correct.
Welcome to the forum and Happy New Year.
Just checking I’ve understood what you’re seeing. Your station console shows the correct pressure and appears to be uploading the correct pressure to WU. WD is displaying the correct pressure, presumably downloaded from WU, as the current numbers value but the pressure plot on the main WD graph is flatlined?
Correct. I was about to message that after a frustrating morning I somehow managed to fix it. Not even sure how. Tech is not for the ancient.
But thanks for your reply. All good now.
