WD and WDL and Windows Mobile 5.0 and Flash and
Here’s the deal. I set up my WD and web page so that I could read the weather at my station using WAP. That worked great on my work BlackBerry. Now I have a Motorola Q with Windows Mobile 5.0 which won’t run Flash, won’t view WAP, and the screen is so low resolution, I can’t view the graphics of my WD! Actually, I did get FlashLite for WinMobile 5.0 but then it won’t read the WDL because it says it is only compatible with Flash 7. ??
So, I’m thinking I just need to start sending one of the many WD gifs over to my web page that will just give me a text line of date, time, temps, wind dir/speed, baro, etc.
Any thoughts, suggestions, etc? (other than dumping WinMobile and going back to the superior BlackBerry?)
What about using WD’s built-in WAP facility?
As he stated…
...That worked great on my work BlackBerry. Now I have a Motorola Q with Windows Mobile 5.0 which won't run Flash, won't view WAP...
One option might be to just create a regular WD-tags page, with a PDA page layout, like I have done here. This however does not include graphics.
Or else you could try this.
More scripts you might like can be found here.
