Is anyone else having an issue downloading the NOAA forecast in WD
I am receiving an error whenever it attempts to get the forecast.
This would under NOAA forecast download.
Receiving this error
Local directory for Noaa download is c:\wdisplay
PWD
257 “/data/forecasts/zone/nh” is the current directory
PWD
Retrieving the NOAA file nhz008.txt now
Saving the NOAA file to c:\wdisplay\nhz008.txt now
SIZE nhz008.txt
550 SIZE not allowed in ASCII mode
141: FTP protocol error: 550 SIZE not allowed in ASCII mode
QUIT
221 Goodbye.
And it nevers downloads the forecast file. Not sure if it’s NOAA change
Anyone else notice this?
I just tried a manual download using WxSimate and it worked OK so maybe the problem has been fixed? I don’t use NOAA/METAR data in WD so I can’t comment on those.
This might be something Brian needs to look at.
You can get the metar to work, just uncheck to use ftp instead of HTTP
and the metar appears to download.
I see a new update was posted on Dec 20th
Will give it a try, I would say Brian has fixed the issue with the new update.
