Thanks…I have seen that script, and I plan on getting to that next. What I’d like to do is get my logo on the (each) image before I publish it. I didn’t see that option in that script…
I needed to do this for the charts on SCWN as shown here: http://www.scottishweather.net/wxcharts.php
I will dig out the php code and post it when I get home from work tonight.
I have found the code that I use and looking at it I use it almost verbatim from the post by jay at zylex dot net dot nz in this link here: http://uk3.php.net/imagecopymerge
Here is the slightly modified version that I use (filenames and paths have been changed):
If you are just simply wanting to add your watermark or logo to your radar image that is easy. You don’t need any special code to do that unless you want to get technical like some have and add other things to the map.
To add your logo or watermark to GR3 just make sure it is in png format and make sure it is named logo. So it would be logo.png. The just copy and paste that image in the folder where you GR3 is installed on your computer and that is it. If your program is open then close it, when you open it back up the image will be in the top left. Then when you click on web publish from the file menu it will upload that image with your logo or watermark on it. simple as cake. Now if you wanted to cut the DBZ or put other watermarks or logos or change the location you are going to need external scripts for that. Their are a couple out there floating around that will do what you need.
This was brought up over at the GRLevel forums before and if I remember correctly their isn’t a way. I think you might be able to create a placefile that will open it to a certain threshold and locations but I can’t remember for sure. I want to say this was something they were working on adding to allow you to set favorites so you can have certain thresholds and views saved. I would check out http://www.grlevelxstuff.com/ for more information and about GRLevel. They have a wealth of info and flash tutorials on using and setting up GRLevel. They also have a ton of free placefiles, colortables, icons, add ons etc for free.
That would be really nice and I have been looking for something like that. I have StartWatch but what good is it starting GRLevel if it is not publishing images because you have to manually start that.
I’ve tried AutoIT and turned the script into a .exe
It worked really great last night during testing, but when I started my computer today, the .exe minimized to the system tray and showed script paused. I can’t get it to go.
